Elevator lift tables are made with thick 10 gauge steel, rugged enough to handle the heaviest vehicles. We start with a quality frame and rectangular base, a footprint that ensures safety in lifting and safety in working. The base frame is fitted with a tow bar that accepts a wheel dolly, the base frame is also pre drilled with to accept a wheel kit which allows for easy placement and storage. A safety locking mechanism is built into the base with 4 and 5 settings, depending on the model, to adjust to your height.
Included are front and rear drop down panels make service work easy, and a side extension kit with ramps which expands the width of the table to 56". The side extension kits allow for service of various ATVs and UTVs. An optional side extension kit which expands the lift table out to 68" wide for larger UTVs.
The Elevator 1800 is a heavy duty lift table carries a 2 year warranty and is built beautifully, you will appreciate its excellence.
CALL OUR SHOP 603-234-2612 WITH ANY QUESTIONS.
VISIT WEBSITE FOR FEATURES,SPECS + MORE PHOTOS: https://www.nhproequip.com/elevator-1800u-atv-utv-lift-table-includes-side-extension-kit
0009433_elevator-1800u-atv-utv-lift-tabl
Register a new account
Sign in
    • By JDawg
      Help...
    • By NC4wd
      Has anyone found a lift kit that fits an Axis 500? Mine is a 2021.
    • By A P
    • By Texjpr
      2002 ranger 500 4x4 stopped running and wouldn't restart. Service manual wiring diagram helped identify the hub safety switch as the culprit. Using jumper wires to bypass  switch allowed the engine to start and run normally. Inspection of switch showed melted epoxy and a strong smell of burnt electrical. Unable to find replacement part either used or new. Is there a work around other than jumper wiring?
    • eManualonline.com Save 30% OFF Sitewide, Use code: XMAS30
