While I don't have a RZR, I just came back from the UTV Rally in Moab and rode with a lot of RZRs. Watching stock to modified for racing, it appeared the RZRs with the shocks & longer axles with bigger tires were the killer upgrades. A couple of guys had turbo but were more trouble than help in Moab. The turbo was great on the flats & sand. Ground clearance was not an issue even for the stocker.
rocmoc n AZ/Mexico
I understand how lift wouldnt be an issue out there.
Where I ride a lift really helps.When I first bought my RZR I stayed c-sawing on logs.The lift and 27" tires really helped.
Did you see any nice custom cages?
  • 4 years later...
    • By NC4wd
    • By Kingfish
    • By Woody77
    • By Tony P
