Thinking about buying one of these for its multi-use. Anyone know if the foot rest for rear-facing riders in the back causes issues in ruts, mud holes, etc?
    • By Dennis
    • By John Doe
      Hello,
      I have a T-Boss 410. When I shift to H it starts beeping like it’s in R. It also shows R on the instrument panel. Fixes?
    • By bms stallion owner
    • By Bryan g
      We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There  is a bulletin Im sure everyone has saw about adjusting shift cable.  That dont always fix it.  I went round n round with coleman  on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair "   I told them shift lever does not have enough travel .  No amount of cable adjustment  will increase travel . I  extended lever with piece on flat  iron by 3/4 of inch .  This gave shifter enough travel to properly engage into gear completely .  Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out,  grease  all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts,  brake hose  routing , make sure not touching exhaust .  These are just  few of the more common failures I see .
    • By downseast
      Hi everyone
      When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
      I haven’t changed the Lambda
      sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
      I believe the T Boss was worked on by the previous owner
