I have a Chuckwagon UTV with a Koehler engine that the entire electrical system is on the fritz. I started out intermittent but now is constant. It will start with the pull rope and shut off by choking it, but turning the key on or off makes no difference, headlights don't work or the 12volt receptacle. I had previously put in a new battery and starter (starter will start it by jumping the solenoid) I have since replaced the key switch which did not fix it. Any thoughts??
THANK YOU IN ADVANCE!!!
  • hammersonranch changed the title to Electrical System Chuckwagon CW300 Dead! 2014 Chuckwagon by American Landmaster
    • By aefron88
