Recently the massimo 500 was starving for fuel. Turn ignition off and on, fuel pump runs a few seconds and stops. Engine will run a little while ten die. Choking air intake with hand will keep it running. Any ideas?
    • By ToughLuck
    • By CapnWalleye
      Greetings All,
    • By CapnWalleye
