POR 15 pictures
By didgeridoo
By Kingfish
By REDfletching
By NHTracker
I have a 2020 Tracker 800SX LE that I bought new in 2020. Yesterday I noticed two cracks in the bed on the inside corners at the tailgate end. They go all the way through. I use it around the property moving firewood, dirt and stuff. Never put stress on the sides of the bed. Has anyone else had this problem? Is there a fix? Help!!!
