are the pulleys Keyed to the shaft, or is it  a taper lock fit?
In other words, You have a straight shaft, straight bore in the pulley with a key, or is the shaft and pulley bore tapered?
On 10/8/2022 at 11:53 AM, Greg Kilgore said:
Agree with Rev limiter. Possible Disconnected the seat belt connection?
Check it for bad connection or broken wire.
No seat belt requirement that I know of on that year Massimo, never have mine on around the farm.
    • By Rick A
    • By FDWT9956
      I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
      Thanks in advance for any experienced thoughts and comments.
    • By SouthernGypsy
    • By se3388
      Steve.............
