Help, who know the kawashaki light plug wire for what?
By GaryC
Unfortunately my rear Diff housing cracked on my 2013 and I need to replace it or find a good used complete differential. I think the same one was used from 2013-2016? Any help or referrals appreciated. Thanks, Gary (949)370-2575 (in UT)
By SayHiToRambo
08 trooper 1100
thanks!
By BMurph
By klm
So here is my dilemma, I bought a 2014 Massimo MSU500 eleven years ago from TSC, its never been off the farm, had my share of ups and downs with it but never walked back to the house. I have bought a Kubota Sidewinder and it is a fine machine.Problem is I just dont need the Massimo and would like to sell it but the last thing want to do is sell it (cheap) to someone who doesn't realize what a POS a Massimo can be and can't afford to maintain it. I plan to put it of Craigslist with pictures and description, not sure how to warn potiential buyers without scaring them away. I feel like it could be a great buy for the right person or a terrible buy for the wrong person. I'm thinking $2500.
By SouthernGypsy
