I need a real mechanics input
By Jon V
By onealmck
By diamondjfarm
Thanks.
By sxr951
parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
By Hunterman22
This is the 2020 updated version from the previous 2009 version. I do not know all the differences. I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
