One Way Starter Bearing for HiSUN HS500
By Graffy
By D MAYNARD
By Alien10
I use my Hisun 550 (with the Coleman stickers), for general work around my 10 acres of hilly land. Hauling firewood, some dirt and mulch, and debris clean up. Also felling dead standing trees in the woods and hauling rounds out to the barn for splitting/stacking.
Here's my question: Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures? Or premature belt wear? Other drive line issues??
Thanks in advance for any experienced thoughts and comments.
