Oil pan spring
Go to solution Solved by Dale Stansbery,
  • Solution
I think you have it like it is in the photo. The spring sits in the filler plug. It's difficult on your back underneath with little room, but you can carefully balance it on the plug. Then compress it into the drain hole until the plug is in full contact with the pan, and then rotate to thread in. The spring wants to resist your effort, but if you're careful and hold it up flush with the pan, it will thread right in. The trick I found was to position my hand and arm so I could press it up and still have enough range of motion left to rotate it. I have an Outfitter 550 with an identical setup.
I just looked at the parts diagram for the oil pump and it also shows an o ring on the plug itself. Be sure it's still on your plug. I don't remember what mine looked like when I changed oil this summer, but it must have been there, at least it doesn't leak. Motor Cycle Doctor has very good parts diagrams for the Coleman UTV's.
    • By Greg Kilgore
      I'm 99.9% sure head gasket is blown.
      Don't have coolant in oil. That a good thing. But think coolant is getting in combustion chamber.
      I did compression test.
      Got 120psi walked away. Came back to 105psi 15 minutes later.
      How hard is it to replace?
      https://youtu.be/N31mOtOPuKI?si=nSnuF4-weRU2T10t
      Advise?
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Cory J
    • By JOSEPH LAMAR
