KUBOTA RTV-X1100 side by side transmission
By Robbie Wyre
By Robby
Hello, I have a 2013 500 utv hisun. Was running ok and cut out while parked. Bike will not start now. It turns over, but won't fire. I have no spark and no fuel. I replaced fuel pump, ignition coil, spark plug, cdi, voltage rectifier and all the fuses and relays. Could bad stater cause no fuel because I can't hear the fuel pump priming. Any info on where to start looking for problem.
