Hi All, again,
Now the Landmaster will not engage in Forward or Reverse, less than 20 hours run time.
Did a quick diagnostic with Navitas Dashboard App, problem:
Bus Under Voltage Fault
Description: Voltage on controller B+ has dropped below 18V
Check batteries, solenoid and connections
(3-1)
Email problem to Navitas.
Still 50% battery supply, charging anyway.
Will check items above plus wiring tomorrow, sun going down.
D. Newton
American Landmaster, EV, Purchase Aug 2022.
Extras - Power Steering, Roof, USB port.
I noticed you added some manuals for your American Landmaster EV, thank you for sharing. Hopefully you will figure out the issue. This is one of the few EV topics I have seen, but I'm sure it'll grow as EVs become more widespread.
Here are your manuals. I edited the screenshot and descriptions.
On 11/10/2022 at 6:55 PM, D. Newton said:
Hi All, again,
(3-1)
D. Newton
Hi All, Well I did some troubleshooting (shotgun work), and I got the vehicle working.  I think the connect was not seated fully in the DC/DC Convertor (48v to 12V).  Not sure, I disconnected and reconnected a lot of wiring connectors.  See Pic1
I was using the phone App, Dashboard from Navatis to communicate with TAC2 EZ-GO RXV Controller, the green brick, it has Bluetooth.  The App is not very stable, I had to uninstall and reinstall to get it to work.  Just a reminder.  Don
    • By Mike Jenkins
    • By Ed Michael
      Subaru SxS.mp4
    • By SteveS
    • By tuell
