If my dad didnt live 3000km away I could get my hands on his CNC machine.. :( I was starting to look around for a nice small turbo to run about 3-6 psi (no idea what the top/bottom end on these engines would be good for) and by searching that I stumbled onto here! BTW, hello fellow Troopers! :D I have a slightly modded Trooper that I will post up pics later for all.
Welcome to the UTVBoard. I look forward to seeing your pictures.
Cinda
Why thank you Cinda, and you beat me to introducing myself! I just recently purchased a 2008 Joyner Trooper T2 with some slight modifications, and I found this forum so far to be INVALUABLE with information on what people are doing to their SideXSide's etc. I live in Grande Prairie Alberta Canada, and you can find me on the weekends usually sunk in muskeg or a mudhole I should never have attempted! :D I uploaded pics to my computer but have no idea how to add them to my "gallery". Im sure a few searches on here and I will find out! See you guys/gals out in the trails.
    • By SpaceGhost
    • By GunnersTacklebox
    • By Jerrys500
      Thanks Jerr
    • By redneckred
      I have a 2012 Bennche Bighorn 700X.  I bought it used.  It had been sitting in a field for several years untouched.  I put a new sun gear in the shifter, new shifter linkage due to the old one having been patched, and a new battery (and of course fresh fuel).  The machine cranked and ran beautifully.  I had it over a year and then the machine quit running.  As it would not stay cranked, I narrowed the problem down to a bad IAC valve.  I replaced it and it ran as good as new/old.  Fast forward, the machine started to act like reverse wasn't catching and would not always back up when in gear.  Then forward quit.  I assumed a bad CVT belt and got one.  Started removing the bolts from the cover and (3) just turn in the housing without coming loose.  (2) are on the bottom, so very little room to do anything with them.  I tried cranking the machine again to see the belt move since I can move the cover enough to see the belt and now the machine will not crank.  It turns over fine.  It gets gas to the injector and has spark.  I can spray cleaner down her throat and she would run until it ran out.  I have replaced the IAC twice and put a new injector with no change.  I went out and put the old injector back in to see if that made any difference and, well, it did.  I tried to crank the machine and the starter is stuck trying to turn the machine over even with the key off.  I have to disconnect the battery to stop it.  Before I shoot this thing, what am I missing?  Is this an ECM problem or something else I am not seeing?  Been dealing with these Gremlins for over a month now and weeds are starting to overtake the motor due to it not moving.  I would love to get the thing running first and any ideas of getting those CVT cover bolts out would be extremely helpful.  Thanks in advance.
