Coleman 550 2019 Engine/trans locked up. Lost oil out of the bottom.
I was riding at approx 30mph when I heard a very loud noise.  Engine immediately died and coasted roughly 50ft.  There was a trail of oil and now the machine is locked up.  Will not crank or go in to neutral.  Machine has 3300 miles.
Sounds like you need to crawl under and take a look and see what's broken, where its leaking, etc. Unfortunately we can not do that for you over the internet.
Post a picture of where the oil is leaking from and we can help identify the issue.
I have never seen a complete hisun engine sold aside from a few random one off sales on ebay.
Did you get a look and determine its dead? What exactly is wrong with it? There are certainly parts available depending on the exact issue. It you want to swap it anyway I would go ahead and remove it and try to figure out exactly what failed first.
Rod came thru the block.  It’s really bad. Side cover and lower section of engine have a large chunk knocked out.  There’s not internal parts that are usable.   A short block might work.    I found a 2018 complete but I am not sure it will work in the 2019.    I’m told 2016-2018 is different that 2019 and up.
Not sure the exact year for cutoff on engine designs, i think the only major change is going from cabed to EFI. Not aware of any short blocks available. Unfortunately might be better off looking at a new SxS.
    • By Cory J
    • By Howard Elmore
    • By rev6engines
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
    • By mark walkom
    • By Reynolds Rocket
