On a modest budget $10k or less trying to find a decent UTV.  Most say for that price go Same Club Coleman is good for $7k or Lowes Axis UTV for $9k or Bass Pro Tracker 600 ATV $9k But seems many say stick with the Massimo because its beefier which is another affordable brand.  I need in the next 2 months.  Use to have a Kawasaki Prairie 450 it was great till it went in for its first service, so dumb to bring it in instead of doing service myself, never worked again.  Now Need something soon to clear some flat land but rough terrain, logs on ground holes etc its the woods that drops off on edge so need it to haul some of our fat arsses back up if we go over the side to haul logs.  Its probably 45 degree incline.  Any thoughts??
I would steer clear of a belt driven machine for heavy towing and steep hills. Under load the belts can start to slip, and once they start you will burn em up fast. These things are really meant to tow light loads, if any. Skidding smaller logs with a log arch might be doable on flattish terrain.
If it's actually 45 degrees you aren't likely to find a vehicle that's safe to operate on it.
Coleman/Axis are both rebadged Hisuns. Massimo is the other major Chinese brand. When looking at Massimo be aware that the numbers don't always correspond with the motor CCs like they do with most other brands, for example a T-Boss 410 is 352 CCs. Tracker is made by Textron/Arctic Cat.
What's the issue with the Kawi?
    • By Joe Breaux
    • By Bobbers
