Utah sXs Group Trail Ride at Vernon Utah
By ned
By Matthew Smith
2013 Bennche Bighorn 700 EFI
Figured I’d check for spark and compression while I was dorking around. Compression is 110 psi, but there is no spark. Replaced the spark plug… no change.
By camojay
By Greg Kilgore
