Coleman 550 Outfitter – Easy Winch Remote Implementation
By hisun junk
I have a 2018 cub cadet challenger 750 with a broke chinese hisun motor and I know that I'm not alone! Almost all the places that were selling them in Colorado don't anymore due to the return for repairs on the clutches and broken timing chains! Don't have yours fixed because it will happen again! They just replace the broken parts with more junk chinese parts! I talked with a UTV mechanic that has replaced one person's clutch 4 times! I have people contacting cub cadet about these problems and also looking into complete motor replacement from hisun junk to a Japanese motor in which the chinese cloned their junk from.
By camojay
By sxr951
parts for massimo, hisun,etc in florida? where can i get parts for the massimo 700.. like bolts and console i didnt see any bolts on amazon to go with cylinders and any thing when rebuilding a 700 engine
By FGT
QUESTION: How to wire the C/B into this current dual battery set up.
EXISTING SITUATION: MAIN Battery is OEM and feeds OEM circuits. Added an AUX Battery in the OEM dual battery location. Connected the AUX - terminal to the MAIN - terminal. Connected the 100A Accessory Fuse Block power cable to the AUX + terminal. Installed a smart isolator between AUX and MAIN batteries where a cable from AUX + goes to the isolator and a cable from isolator to MAIN battery + terminal. Installed separate QD battery tender cables to both AUX and MAIN batteries + and -. The dual battery system appears to work as intended. For this Phase 1 improvement, to avoid having to constantly pull the leads on the AUX + battery post off and put on, for testing or maintenance of Accessory circuits, I wanted a more convenient and safer way to open the circuit from the AUX battery + terminal the Accessory Fuse Block. I called an off road dealership and was told to install a much larger capacity circuit breaker than the 100A rated Fuse Block and was recommended to get a 250A C/B like the one in the pic, which I did. I was told the reason for the C/B high amp rating was two-fold (a) to trip in the event of a battery short circuit and (b) to be able to conveniently open the C/B to kill power to the Accessory Fuse Block without removing leads from the AUX + terminal. The 250A C/B has two posts labelled "BAT LOAD" and "BAT LINE". There are currently three connections to the AUX + post: (1) Accessory Fuse Block power cable, (2) cable to Isolator AUX in terminal, (3) cable from AUX battery charger.
