Went for the first ride of the year this weekend in the Uintas . I came back and was doing some checks on the
trooper and noticed some looseness in the right rear wheel bearing . I checked the left rear and it is tight.
Looking at the parts breakdown I don't see any preload adjustment capability . Iam wondering if I should
just drive it and see if it gets more loose or do you think I have a bad bearing .I only have 245 km on it .
Also wondering if anyone has had any engine oil leak issues . I noticed a few drops on the skid plate right
below the crank pulley. I cleaned it off expecting to see more oil drops ,rode the rest of the weekend no more
leak, very strange ,oil leak are usually not intermittent any thoughts ? thanks
Guest Lenny
No adjustments on th rear wheel bearings. It's nothing more then a double roller bearing not more then about 2" long total. I'm amazed that it holds up at all. It just has no width to it. The stress on the bearing has to be way up there and a bearings life span is directly related to the load put on it so I don't expect them to last real long. Also check the thread "Rear wheel misalignment issues" (same Joyner forum). There are other things that can make the back wheels loose.
Really? there not taperd wheel bearings like the front?
Guest Lenny
Sorry, I said roller bearing, it's a double ball bearing. That's worse.
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By tskm
      Tom
    • By TPlummer
    • By JimWil
      Looking for a place/website to order a  replacement bench seat and a dump bed fender from.
      JimWil
