KMS Performance is excited to offer a simple solution to the touchy RZR throttle pedal. A heavy duty throttle spring is now available to replace the OEM spring. Simple installation in minutes to get you back riding. No more bouncing around at low speeds.
View the full article
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
    • By Howard Elmore
      I have owned mine for a couple years now but newer took off road.  How well does it do trail riding m?
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
