What has failed or broken
15 members have voted
  1. 1. What has failed or broken
    • Drive Line
      6
    • Front Shock
      1
    • Rear Shock
      4
    • Differential
      5
    • Ball Joint
      4
    • CV or Axle
      5
    • Computer
      1
    • Electrical System
      6
    • Steering
      2
    • Fuel System problem
      3
    • Oil Problem
      1
    • Engine Trouble
      0
    • Ignition Problem
      0
    • Oil Problem
      1
    • Stock tire failure, not just wore out
      8
    • Power Train Problem
      3
    • Clutch
      1
    • Starter
      4
    • Over Heating
      6
    • Fuses
      8
(1) Drive-line not installed correctly when delivered from Phoenix Not pressed into trans, March 2008
(2) Drive-line taken to shop and repaired, first time taken out the driveline comes apart at the back, the pin and carter pin not installed correctly.April 2008
(3)next day front flat
(4) electrical problem summer 2008, no warning just stopped running
(5) two more flats at same time, unrepairable pin holes in side walls summer 2008
(6)May 2009, drive-line fails
(6) seat latch breaks, seatbelt breaks May 2008
1. ??? 2nd Ride, right rear CV joint came undone at the wheel
2. 252.9 U joint, replaced with another U joint drive line
3. 691.8 Drive line, replaced with CVs this time, LF Shock, Rear locker
4. ???? Had a hole in the rim caused by a rock wedged between rim and brake caliper. No fault of Joyner
5. 1540 Tube left rear tire\
6. ~1600 Ball joint fell out.
7. 1702 CV joint again, Right rear shock ($149.03)
8. 1742 replaced dust boots on tie rod ends and ball joints, cracked
9. 1991 Fused blown ( by sensor wiring found later)
10. 2069 Fused blown, Found fuse was blown by O2 sensor wiring
11. 2437 Tube Right rear tire
12. 2836 New tires, General AT,
13. 3069 Right rear axle replaced by Joyner, finally after 3 time coming loose
14. 3357 Bolts in read differential failed.
15. 100,000 No more problems, yea, in my dreams :D:lol:
First ride 10km bolts came loose off of shifter linkage (no 5th gear or reverse)
Same day after fixing shifter linkage cooling fan warped fan blades hitting housing
Second trip 50km front and rear diffs leaking found both grossly overfilled from factory,left rear tire going flat,
same trip noticed right rear shock making noise (spring is rubbing on shock body) have nor replaced yet
third trip last weekend evidnece of engine oil leak , just insatlled joyner cargo rack plastic vibrates like hell
(on the to do list) trailored home in arain storm 4 of 6 headlamps and spot full of water disassembled lights
and siliconed headlamp lenses next trip June 20 ???????
Left rear tire, pin hole leaks at top of side wall. Leaking from day of delivery.
Rear shocks squeaking after 1st ride, finally replaced with Kings.
Misc. loose bolts.
Rear differential leaks oil at seals after 1st oil change, my fault from overfilling although the front has never leaked.
Top acc. cargo rack rattles like crazy. Repaired it a couple of days ago.
Flat right front tire, rips in side wall, might have been those rocks I hit, now the spare with tube inserted.
  mlg said:
Did you replace just the rears with kings or did you do all 4 ?
I replaced all of them. Area that I ride in is rocky desert terrain and the stock shocks were just too stiff. Even playing with the spring preload and nitrogen pressures they were just too harsh for my bad back.
The first time out, maybe 10-15 miles. When I got back to the trailer, 3 out of the 4 windshield bolts were missing, and a hex bolt to the rear cage. After that, I stopped at Home Depot and got some lock washers and then went and got 4 things of blue Loc tight. Best $20.00 I ever spent
This topic is now closed to further replies.
    • By mark walkom
    • By J-ree
      hello, I’m new to this website and I joined as sort of a last resort. I bought a China built machine, witch was my first mistake, used it on my Farm for Number of years. Then, I broke it. I spent for ever looking for parts. I can’t find any anywhere! So I came to you. Does anyone out there now where who might have anything that will help. I am open to almost anything. My rear has a straight axle like an old car.  I could change to other styles. All I need is something to work with.  Thanks for listening to me........ Jerry
    • By Hisun .500
      So my hisun 500 is tore up and all the wiring is wasted i was wondering can i pull out all the wiring and just put in the. Basics .please help
    • By Bennche x4
      Has anybody put portals on there bennche x4
    • By robwork9
      Hopefully someone out there is a T-Boss 410 electrics expert or a Massimo mechanic is viewing this. I parked my 410 and it was working great. I came back a week later and attempted to crank it and nothing. Turned the key and no power. Figured it was a bad/low battery so I charged it. Still nothing. Attempted to jump start it and still nothing. Usually when I put the key in and turn it to the first position, the display comes on and I hear the ECU and other items boot. Now it is doing nothing.
      I slowly went through the electrical system and found the main fuse attached to the starter relay, part 71602 (pic 1) blown. I figured replacing this fuse would fix my problem. It didn't. I then ordered a new starter relay thinking maybe that part had gone bad and caused the fuse to blow, but a new relay did not fix the problem.
      I have found a work around for starting the machine. If I take one of the purple/black leads (pic 2) and insert one of them in the bottom right of the starter relay (pic 1 and 3) then the machine will get power even with the key in the off position.  I'm bypassing something but don't know what. I can use my right hand to hold the wire against the lower right of the starter relay, reach over and hold the brake with my foot, then take my left hand and turn the key and it will crank. As soon as I remove the wire from the relay the machine shuts down. I have even removed the power distributor box and it will still get power when I touch the wire to the relay. Of course this is not the way it should work but if I can't solve this problem somehow I may just have to rig a connector to the relay and bypass whatever is causing the electrical issue. Massimo has told me the purple/black wires on my model are not used.
      Any help in figuring what my problem may be or other items I can try?
      v/r,
      Rw
