do you already have a gas gauge on the dash??? If not then it could get complicated. A sending unit would need to fit in the tank, and then wired to the dash. There are alot of different possibilities, but accuracy of the whole set up would be questionable. Does you Ruesch have ametal or plastic tank? A.
  • 3 months later...
    • By Rick A
    • By weasel
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Buddee
      2010 Hisun 500 - Carbed'.  She sat for about 3 weeks since last use.  Couldn't get it started.... has spark but plug was not wet.  Bought new plug, cleaned the carb, confirmed fuel pump (pulse type) is working.  Still nothing.  Put gas in the plug hole.... started right up and idled as normal and drove perfect.  Used it for the rest of the day without issue.  Tried to start again next morning.... same problem.  Poured gas in plug hole again.... started up and best kind again.
      Anyone have any insight to what's going on?
