2022 Uforce 600
Coffeeman
I got one last November.  It has been great to ride and use around my property.  The only down I’ve found is the jerky start.  You probably heard about that already in your research.  I didn’t run right out an buy a clutch kit which seems to be the popular answer.  I just patiently worked though the break in period and found the jerkiness has largely gone away.  Easy on the gas and even start.
    • By diamondjfarm
      Thanks.
    • By mac66
    • By sxr951
    • By aefron88
    • By mcraigchr
      I realize that many of you do not have diesel machines.  For those that do, this is for you:
      Just wanted to post my experience this past week.  Here in Texas, we had pretty good dip in temps.  For 4 days it did not get above 25.  At night, it was single digits or close to it.  I always put Sta-Bil fuel stabilizer in the storage tank (30 gallon).  And up until this tank I was using Power Service (white bottle) for anti-gel.  Never had an issue.
      This tank, however, I switched to Stabil All season (anti gel).  It is supposed to good down to -40.  Zap.  That is a big fat lie.  I put in twice the amount called for in the instructions.  Result was less than optimal.  I drove the SxS 100 feet (to go get the mail) and it died.  I looked at the fuel bowl and it was a cloudy, wax substance.  So, the Stabil did not work.  That said, I'm not sure that I ever tested the Power Service in the same manner.  So I am not saying that one is better than the other.
      What are your experiences?  Are these products inferior?  What do you folks in the northern states / Canada use?  Am I missing something?
      CC
