I got one last November.  It has been great to ride and use around my property.  The only down I’ve found is the jerky start.  You probably heard about that already in your research.  I didn’t run right out an buy a clutch kit which seems to be the popular answer.  I just patiently worked though the break in period and found the jerkiness has largely gone away.  Easy on the gas and even start.
    • By aefron88
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By SpaceGhost
      They will be coming off.
    • By Nikonianut
