By Will Sutton
By dman66
By John Gubancsik
I started my UT400 but forgot to buckel my seat belt. It bogged down and then died. Only way I could restart it was to press the gas pedal and if I let up on it, it stalls. Any suggestions? Thanks.
By Rainman
I just picked up a 2021 Coleman UT400 and one of the things it needs is a gas cap. I believe it needs the 2021+ version with mail threads. Anybody know where I can get one? Coleman isn't shipping anything out right now. I believe the part number is P315001811400000. The only after market gas caps I see available are before 2021.
By John Gubancsik
I'm having trouble finding a replacement battery for my UT400. Has anyone bought one and where did you get it? Thanks.
