kawasaki FLAG
By hdtran
By sxr951
By strike250
Matt
By Travis
View File Kawasaki Mule 550,520,500 Complete service manual
This is a complete service manual for the Kawasaki Mule 500,520 and 550 models.
Topics covered include Brakes, Steering, Electrical system, suspension and fuel system. As well as engine repair procedures and Transmission/Final Drive procedures.
If you need more information about the engine this manual linked below is chock full of information.
Thanks goes to @cliffyk for getting these files all into one PDF format for uploading.
Submitter Travis Submitted 04/18/2021 Category Kawasaki
By ILoveOldJunk
Recently acquired a 21 year old Mule. The previous owner let the brake master cylinder run dry, and when I flushed the brakes, one wheel's brakes locked up. I took the wheel off, but cannot get the axle nut off, and there is not enough space to get my gear puller behind the drum anyway. Anybody had an issue with seized brakes? How can I get this thing off to replace it or rebuild it?
