I bought a 2021 Coleman 400 UTV from Tractor supply mainly because of the $2000 off black Friday sale ($6999). I wanted something to do some light hauling around the boat shop and figured this would be a better choice than a golf cart. Initial review is that for the money,it's got to be the best deal going. Fully equipped right out of the box with a lot of nice features. First off,everything worked,that's a good thing. First thing I noticed is that this thing is LOUD,so loud that I use foam ear plugs to run it. The rear axle is locked,like most 4 wheelers,so the tires scrub on tight turns and will tear up the lawn. I found some loose bolts and did a general inspection of everything and tightened up the loose ones as I found them. It's cold here in SE Michigan and I want to do some recreational use during the winter. I bought a 3 Star door and rear window soft enclosure and installed it. Top quality materials and fit great. I added some foam to close off all the gaps and it really does the job. Next I added a Ice Crusher heater kit that uses the coolant to provide heat in the cab. Quality parts and the kit was pretty much complete,I also added a coolant shutoff valve so I can direct all the coolant through the heater instead of the radiator,or blend it as I wish. The heater has a 3 speed fan and 2 directional outlets for this model and with the enclosure will warm it up to shirt sleeve temps at speed with the outside temps in the low 30's. I also added a Kolpin Stealth 2 auxiliary silencer, the exhaust note is definitely quieter and less raspy, but this rig is still noisy enough at speed that you need ear muffs or plugs. I changed out the headlight bulbs to LED's which are a big improvement from the halogens. I figured out a trailer hitch adapter for the oddball thing Colman provides. Now it's just run it in and break it in. For a 400, it is actually quicker and faster than I expected,the specs say 38, but it's closer to 50. Brakes are powerful and smooth. The solid rear axle makes this thing pretty capable,but you also have the push button 4 wheel drive and a push button front diff locker if you need it. All in, it's set up just the way I wanted it for under $8000.
Welcome.
If you have any questions there's plenty of info in the coleman and hisun forums (it's a rebranded hisun, but most of the 400 posts are in the coleman section) there's a couple posts in each about things to help quiet these machines down.
People have had good luck with adding various sound deadening materials under the front/sides of the seat and under the bed.
I would love to see a post about the heater setup with some installed pics. I've seen them listed but you're the first person I've heard of actually installing one on a 400.
    • By SkyPilot56
    • By klm
