Just bought a used 2015 500lm, any advice on what maintenance to do first? It's kind of a pain to run through the gears, how do you adjust the cables that go to the shifting 'wishbone'?
It feels like the shifting is also tied to the idle speed?
Any thoughts fellow owners?
-GCHND
    • By Dennis
    • By SteveS
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
