On the hour counter, lower hours = higher trade in value, we all know that. What if the key is left on and it drains the battery - is the counter powered by a separate source and will it continue to click away in spite of a dead battery? Seems odd that it would, but someone has told me that since the key was inadvertently left on for several days, the hour counter has racked up several days worth of hours. :o
  • 4 weeks later...
    • By Gorj
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
    • By Rainman
      Thanks in advance ...
