Question - what is the BEST Off Road Forum for a Major Mule Pro FXT Transformation Project
Am starting a major transformation of a ndw Mule Pro FXT to turn it into a Reliable Scouting & Hunting Vehicle.  Interested in first finding the absolute best off road forum that has great participation the more technical areas like planning accessory wiring, ground clearance options and bracket lifts.  Someplace where people who know how to do stuff, participate.  Is this a good forum for more technical stuff and where there are Mule owners who upgrade and work on their machines? My project is taking a new Mule Pro FXT and taking it through a complete project from adding lots of electrical, adding a fuse block, ground block, OEM heater, dual battery system, gun rack, sound system, nav display, inverter power outlets, 360 degree LEDs, cabin lights, W/S, phase 2 upgraded tires, full cab, rear W/S, and so on.
    • By GunnersTacklebox
    • By Blair
    • By Xov
