water pump for the trooper
By Grant
By SouthernGypsy
By mark walkom
By Fordman1
Cleaned fuel filter and am replacing mechanical fuel pump. Unbolted but can't get fuel pump out. Shaft sticks out and fuel pump hits axle and won't come out. Anyone had this problem?
