Amazing! Not sure what other word to use. This is one of the few weekends that I didn’t have to work and so what do I do…head to Chula Vista to camp for the weekend and watch the CORR races! I guess it is just in my blood…why clean the house, that’s what [...]
View the full article
    • By Jacob E freeman
    • By Kingfish
