2016 Mule 4010 - Overloaded Payload, now Mule won't go fast & lacks power
Go to solution
Solved by cliffhodges,
Picked up an essentially new 2022 UT400 with 9 miles on it. Decided to change the oil because it's probably never been done. Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out. What should I start checking?
By Eagle Mountain Outfitters
By Kingfish
By felo72
By WCF
Hi Joyner Gang
