Working on a 2003 Kawasaki Mule 3010 and I am having issues with it at idle. I noticed what looks to be the vacuum feed line to the vacuum T mounted inside the frame hanging. For the life of me I can not find where this hooks up to on the engine, carb, or intake system. Any help would be greatly appreciated!
    • By GunnersTacklebox
    • By Duane Baker
    • By Bbicon
    • By aefron88
    • By Dennis
