If it's in park or neutral it will redline but if you put it in gear it will go about 3mph then start chugging and acting like it's hitting a rev limiter or limp mode.its not slipping and I can't find any vacuum leaks.any ideas
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By bms stallion owner
