Differential Upgrade Kits are available
By Prepper
By Grant
By CYJSP2009
Dear Friends,
2022 Brand new Joyner CV Axles and CV Joint rebuild kits are comming
1. S650.03.02.02.00 ---Joyner 650 Commando Rear
7. 14274 --- 650 ider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
8. 15803 --- 650 Sand Spider rear left, rear right, 800 MV; 800Viper, SV1100 Drive shaft rear left and rear right outer cv joint rebuild kit
Price: CV Axle: USD250/ Piece; CV Joint kit (without grease): USD110 send to door.
Buy 1 piece: Get 5% discount,
Please kindly note Qty for each part is not big and it is hard to forcast when there will be next offer for these kind of products unless there is sufficient confirmed order qty for productioin arrangement.
Payment method: Payoneer payment link ( can pay through bank account or credit card) or Paypal ( casey@leafasia.biz) . Payment commission paid by the buyer.
Interested parties, please contact casey@leafasia.biz.
Good Luck
Casey / Leaf Asia
July-07-2022
By Frank Mac67
- NO CLICK - NO OTHER NOISE
Can anyone help?
Can anyone help with this?
By Tejun
