Odes?
By A P
By clint501
By SteveS
By tuell
Hi everyone I have a 2016 hisun vector 550 with 1320 miles on it I recently replaced the clutch the bell the belt the one way bearing basically everything inside the primary and drove approximately one mile my side by side just stopped pulling... no noise no smoke nothing the belt is still good but it's like the transmission will not engage in any gear any help would be greatly appreciated.... I have lifted the rear end and started the side to side put it in gear Wheels do not move but you can turn them by hand
By Frank Mac67
- NO CLICK - NO OTHER NOISE
Can anyone help?
Can anyone help with this?
