Headlight Bulb LED Cross-Reference???
By FTG-05
By ned
I have a Kubota RTV -X900 that I recently got from someone that is in good condition. I'm trying to determine what year it is all to no avail. I have the 16 digit product identification number and have gone on line to multiple sites with no luck. The number is A5KB2FDBCFG024444 . I'd appreciate it if someone could give me an idea where to look this number up and get the year on this unit. Thanks in advance.
By lincolnsq175
I have a 2020 coleman ut400.
Any info is appreciated.
By SpaceGhost
They will be coming off.
By Bryan g
We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There is a bulletin Im sure everyone has saw about adjusting shift cable. That dont always fix it. I went round n round with coleman on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair " I told them shift lever does not have enough travel . No amount of cable adjustment will increase travel . I extended lever with piece on flat iron by 3/4 of inch . This gave shifter enough travel to properly engage into gear completely . Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out, grease all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts, brake hose routing , make sure not touching exhaust . These are just few of the more common failures I see .
