TROOPER - TURN KEY - SOLENOID CLICK - NO START
By Rick A
By Ken rung
By rocmoc
This is rocmoc/Michael one of the first on this forum when the Joyner was one of the most active topics. First an update of others. The earlier members will also remember Lenny and Jeff. With myself we organized the first Jamborees in 2009-2012. Sadly if you have not heard we lost both Lenny and Jeff in 2018. A great loss to the community. Myself: Still around but rolled over to Jeep and Arctic Cat Wildcat. The Wildcat design still remains me of my old 2008 Trooper. Doing well as the Last Man Standing but cleaning out the garage. Found some New and used Trooper parts I will list in the parts section. Wanted to give you all a chance before I list on Ebay. As many of you knew Lenny listed a lot of stuff on Ebay. Will I partnered a lot of the stuff with him and I still have stuff. Take care and I will check in for message should you want to ride. Still make it to Utah every other year and am still in Southern AZ.
rocmoc in AZ/Mexico
By Greg Kilgore
I did compression test.
How hard is it to replace?
Advise?
