Coleman ut700. (Hisun).
leaking from the output shaft from engine. Parts diagram shows the nut, metal washer, then the flange coupler. However when I took it apart, there was what was left of a plastic bushing. Assuming it seals between the washer and splines shaft. But the parts diagram doesn’t show this plastic part. What gives? Thanks in advance.
  • Alex changed the title to Coleman UT700 Output Shaft Leak Need help!
    • By CapnWalleye
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Bobbers
    • By Marie
