the owners manual is a big help....not...
Error code
In the event that an error code is displayed instead of
the hourmeter or the odometer, note the error code and
then turn off the engine. Restart the engine next. If an
error code is displayed again, consult your KUBOTA
Dealer.
  • 1 year later...
    • By Paul L
    • By downseast
      Hi everyone
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By Reynolds Rocket
      I have a 2017 Intimidator XD4 800cc 4x4.  It will run great and then it's like it goes into safe mode and only runs on 1 cylinder.  It's not fouling out the plug when it happens.  Some times when I stop and restart it, it works fine.  First I thought it was a spark issue, then a fuel issue, but I feel like it's a short in the wiring some place.
