Has anyone tried adding a water methinol injection to a Turbo trooper. I think I am going to give it a try see what happens I should be able to run 10-12psi boost with premium gas and not have to worry about detonation.
    • By SteveS
    • By Cletus
    • By rocmoc
      rocmoc in AZ/Mexico
