Off-Road Baja Tours in UTV's
By Alien10
By hdtran
Hy (pronounce he), just bought a Hisun Sector E1.
I'll be using it to haul logs and stuff in the Sangre de Cristo mountains.
By J R
Hi, I just bought a used 2015 MSU500 with 365 hrs on it. After riding it the UTV seemed sluggish and would not climb a moderate hill without getting a running start in low range. Took it to a repair shop and they told me that the clutches were burnt and slipping. Had the primary clutch replaced and afterwards was told that the compression of the cylinder was only 80psi, which I was told was 100psi below original compression. I've bought all parts necessary, including new crankshaft and bearings to rebuild the motor. My question is, does anyone know if a 700cc top end kit will bolt onto the 500 motor case?
By Alex
View File 2017 Textron Off Road (Bad Boy Offroad) Stampede Owners Manual
Submitter Alex Submitted 01/03/2021 Category Arctic Cat/Textron
