I've been having misfire issues with my UTV 400 when it gets warm and I've thrown all kinds of parts at it so far with no permanent resolution. Today I removed the O2 sensor and it is black on the end. To me that means it's running rich and/or the sensor isn't working. I replaced the sensor with a new one and will see how it goes I guess. With EFI, I'm wondering why the sensor would be this way with low hours and mileage? Is there a way to adjust or lean out fueling on these? Thanks in advance.
By bms stallion owner
hello, my BMS Stallion 600 is having accleration issues. the manual fails to show final gear oil diagrams very well... I have the owners manual and suspect issue is associated to transmission , I want to check the level of the gearoil. I located a drain plug (but not the fill plug nor dipstick). It will run - but wont exceede 2mph. Troubleshooting suggestions or comprehensive manual suggestions? Thanks
By Roadstar515
Regards, Rick
By allinone
Recently purchased 2nd hand not going Crossfire GT400 (Australian branded name?) 2020 model. Has some issues what would be the best forum to pose questions.
