    • By Troy C
    • By Brett
    • By Mike McDonald
      I have a 2014 Intimidator and need brake pads and calipers. The price for pads and rotors are outrageous through the dealer. I have heard Intimidator used the brake assembly from a compact car when first building these UTVs.
      • Can anyone tell me of a less expensive source to buy brakes for Intimidators from,  or
      • Can anyone furnish information on what make and model vehicle Intimidator  used their brakes from?
      Thanks so much for any support you can provide me on this topic.
      Mike
    • By tskm
      Tom
    • By Hutch
