Well after yrs. plowing with a ATV with a manaul plow set up I want to update to a Ranger Xp and a new plow system.
What type of winch should I buy and why is one better then the other. I have the same question about the plow systems out there.
Thanks for your input.
IMHO.... winches are rated for stuck weight. So if your Ranger weighs.. lets say 1500lbs. loaded, you probably would need at least a 4000lb. winch. It's better to go bigger than come up short on pulling power. The standard is probably WARN. very good product and good support. As for the plow the latest greatest set-up is the "quick mount" which is offered by "Moose Industries." This allows for easy mount and dis-mount of the plow, without having to get down on the ground for hook-up. Also the you might preferr a winch w/ a remote. this makes for more comfortable plowing, not having one hand on the dash all the time.
Good Luck A.
    • By Smittay
      I saw that Intimidator is offering a $7k rebate on all their UTVs. This looks like an amazing deal. Are their UTVs any good? I looked through the forums and there appears to have been some problems in the 21-23 timeframe? Does anyone know why in the world they would be offering such a steep discount?
    • By rdborra
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
    • By SpaceGhost
