Joyner's New Owners
By Xov
By FTG-05
By SpaceGhost
They will be coming off.
By CRV
Howdy new member here . My hobby's Rabbit dogs , gamefowl . I'm retired from my real job but I stay busy with the hounds and gamefowl . So to help around the farm I ran across an old 2007 CC Big Country 4x2 to haul feed , water , sprayer and my sorry a$$ .It is in pretty good shape , 781 hrs. good plastic , tires, ect. . But as anything outside and 18 years old it needs seats ! The thing I have found wrong mechically the Diff. Lock Acturtor is broken where it mounts to the bracket ( partly why Im here ) . Hoping someone here can help ! Just my wish list but Id like to find a roll cage and a composit/plastic top for it Im thinking I'll need a donor to salvage these things from ( again partly why Im here ) .Is there another brand that uses this same actuator? If anyone reads this and has or knows of any of threse parts PLEASE HOLLER !!
By Prepper
Hello All...
Just bought a 2014 Massimo 500 UTV. It;s not running at the moment, but hopefully will soon. I need a seat for it also (passenger side, if it makes any difference.) It is a crank-but no start situation. Just now starting to read the boards for solutions. Apparently these models are well known for this issue. If anyone has any suggestions, please feel free to chime in, it would be greatly appreciated.
