What do you mean by "relearn procedure"? ECU reset? How did you perform this?
Did this start with an outdoor temperature change? IE it ran fine when it was warmer out but now that it's cold it dies at idle.
If you give it a little gas does it stay running?
I'm wondering if the coolant temp sensor might be giving a false reading which would adjust the fuel map to where it won't idle
The ECU relearn procedure is done by holding the accelerator to WOT for 3-5 seconds and cutting the key off while @ WOT. I don't believe temperature is affecting it, I live in MS. The bike while die at any range in RPMS and giving it gas does not help keep it running. It just suddenly dies. No symptoms to lead me to believe it is a rich/lean condition or poor idle speed. Just shuts off but can turn the key off and back on and it fires right back up until it stalls again.
Check out the "Run Low on Oil" sender; make sure that it is plugged in and works.  Sounds to me that something like the oil sender has a timer and is causing your machine to shut down.
  • 7 months later...
  • 1 year later...
I guess I’m thinking along the same line as Motojoe. Does the oil light precede the shutdown, occur with shutdown or come on after the engine quits. In view of all the components you’ve replaced, I’d be looking hard at sensors. The more of these kind of problems I hear about, I think I’m going to invest in a code reader. Hope you saved all your old stuff for possible future use or sale.
Pop Bob
On 1/9/2023 at 11:40 PM, Jon Spruill said:
Hey do me a favor and unplug both
your O2 sensors and let me know if it stops stalling
  • Thanks 1
Pop Bob
Do me a favor and unplug both O2 sensors and let me know if it stays running
  • Thanks 1
Pop Bob
Unplug both O2 sensor and please let me know if it stays running
  • 6 months later...
    • By Grant
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By rdborra
    • By Flanman55
