3400 diesel 2011 trouble shifting from reverse to high or low
This is a new problem for my 3400. When plowing, it shifts into reverse with no problem. When I try to shift to high or low is when it’s hard, sometimes VERY hard to get it in gear. What’s up?
    • By Ed Michael
      Subaru SxS.mp4
    • By Xov
    • By Paul L
    • By bms stallion owner
