Just purchased  a 2009 polaris crew , Want to a add a few accessories , Have options for safe and more electrical  power,  1 add 2nd battery with a isolator  or separator    or 2  add a auxiliary fusebox with a large  relay and breaker fues like some  have done, Any thoughts,  Thanks
    • By Cletus
    • By Rainman
      Thanks in advance ...
